I have a waterthigh problem that appears when I export this file in .stl and .stp. Could someone export it and explain me what I should do to fix this?
I am working on autodesk inventor professsionnal 2014 student version, on windows8, 64bit.
Thank you,
Carmen
Why did you not use a Pattern for the Hole features?
Can you attach a *.stp and *.stl file here that exhibits the problem?
Why is the Coil feature done as a separate body and then Combine-Cut rather than Cut in the Coil feature?
Drag the EOP up and save at each step till the problem occurs.
I would re-model the part from scratch, significantly simplifying the feature tree.
The CADWhisperer YouTube Channel
Thanks for your answer. I am a real beginner with inventor (actually with 3D modeling in general), so I guess there are much easier and better ways to do.
I attached a .stp file, you can see that weird patterns appear in the spiral groove.
Carmen
Carmen
The *.stp file looks identical to the original on my machine. Can you post a screen capture of what you are seeing?
I suspect that might be a problem with your graphics card rather than with the geometry.
Try these two things
Set you Visual Style to Shaded with Edges
go to Tools>Application Options>Hardware tab and set to Software graphics.
Do you see any difference?
Not sure if your Inventor 2014 version are up-to-date, so far the Inventor SP2 and its Update2 had been released. You can also try to install them if not.
Inventor SP2 download page: http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-i...
Inventor SP2 Update2 download page: http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-2-f...
@Carmen1666 wrote:
I am a real beginner with inventor....
Carmen
Check the attached file (I didn't include the text).
I changed the 16° hole a bit - make sure however you end up modeling that feature, that it can be manufactured (I am assuming a thru-drilled hole).
See if you can reproduce the attached model. (created in student license).
If you edit the attached file - pull the red End of Part marker above Hole1 while you do the text and Extrude-cut. Then pull it back down after finishing. This will make it easier for you on re-build time while working on the text.
