I am trying to export a PART List into excel. But, can not seem to be working.
1. Double click on the PART List to edit
2. Click on the "Export Button".
3. Type a name of file "Project PART List"
4. Click "SAVE". seems to be working as it allows you save.
Launch windows explorer and search for the file you have just save. (No item match your search)
Solved by Paul-Mason. Go to Solution.
Hi Willie,
Did you specify/change the folder for the excel file? This excel should be located here if it was created.
For some reason the export parts list to Excel dose not like, or can not cope, with a table name in that particular box just leave it blank and if wanted add the table name manually in excel.
Hi Mingwei Gao,
Sorry for the late reply as I was on holiday.
Yes, all of the files are in 1 project folder.
Hi Mason-Paul,
That is a good workaround. Thank you for that.
