Inventor General Discussion
New Member
f_couto
Message 1 of 2 (262 Views)
Exporting Dimensions from Inventor 2013 to ProE/CREO
262 Views, 1 Replies
09-12-2012 08:37 PM
Hi, I was wondering if somehow Autodesk Inventor 2013 could export the sketches and dimensions of a part to ProE/CREO.  I've tried using an IGES format and exported the part from Inverntor to CREO, and I get the part with the dimensions and everything, but not the sketches or the extrusions,etc.  Just the plain part.
Also used the .g and .neu , and still nothing.
Employee
KevinLi-Autodesk
Message 2 of 2 (250 Views)
Re: Exporting Dimensions from Inventor 2013 to ProE/CREO
09-13-2012 01:23 AM in reply to: f_couto
Hi f_couto,
Thanks for your report.
When you export to .g or .neu format there is an option "Sketches" in Save as dialog box, please check it on then the sketches can be exported, but the Sketches here only includes curve, the dimension and constraint cannot be export, about extrusion feature lost (you should only see a base solid), this is not Inventor software specific behavior as other 3D CAD software cannot achieve this which I believe. But you can use tool "Inventor Feature Recognition" from Autodesk Lab to recognize the features, it is free and you can get installer from: http://labs.autodesk.com .
Kevin Li
Quality Assurance Team
Kevin-Hongyuan Li
