Inventor General Discussion
Distinguished Contributor
Anthony
Message 1 of 9 (826 Views)
Exporting BOM Lists
826 Views, 8 Replies
03-22-2012 04:37 AM
It would be good if there was an option to export a bill of materials in word format (.doc) instead of just Excel, is there a way to do this in Inventor 2012 ?
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Cadmanto
Message 2 of 9 (822 Views)
Re: Exporting BOM Lists
03-22-2012 05:01 AM in reply to: Anthony
Anthony,
You can RC on the BOM and select export.  Then under the file types there is a .txt file
type.  These can be opened up directly inside of Word.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Anthony
Message 3 of 9 (816 Views)
03-22-2012 05:11 AM in reply to: Cadmanto
Thanks yes I did see that option, it would be even better if there was a direct export to .doc option instead of this so that when the .txt file appears in Word there is no need to 'customize' the data to view correctly in Word. Maybe one for Autodesk to think about in the next release.
PaulMunford
Message 4 of 9 (807 Views)
03-22-2012 06:36 AM in reply to: Anthony
You can't do it directly, but the option is available 'Under the hood':
Check out this example from Brian Eakins:
http://modthemachine.typepad.com/my_weblog/2010/02/parts-list-with-thumbnail-image.html
CSO
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Cadmanto
Message 5 of 9 (795 Views)
03-22-2012 12:43 PM in reply to: Anthony
At least there is an option.  Might be your only one.
Best Regards,
Scott McFadden
Anthony
Message 6 of 9 (782 Views)
03-23-2012 04:20 AM in reply to: PaulMunford
I have another question: I have renamed some parts in the BOM list so as to enabel them to be grouped, the problem is I loose the thumbnial when doing this, can you advise on how to retain the thumbnail when renaming and grouping parts ?
PaulMunford
Message 7 of 9 (772 Views)
03-23-2012 03:12 PM in reply to: Anthony
That makes sense to me. The Thumbnail comes from the part file. If you roll up two or more parts, how will Inventor know which one to take the Thumbnail from?!
CSO
Anthony
Message 8 of 9 (760 Views)
03-26-2012 12:33 AM in reply to: PaulMunford
I am grouping exactly the same part so Inventor should retain the thumbnail image as it's the same part !
tech
Message 9 of 9 (641 Views)
12-11-2012 10:01 PM in reply to: Anthony
Hi have a look at BOM Tools. I think it can do what you need.
http://www.mgfx.co.za/tools-for-inventor.htm
