Inventor Forum
Exporting AutoCAD dwg files from idw files
3 REPLIES 3
Barry1Lau
732 Views, 3 Replies
Does the exported dwg file always have to be a zip file?  I have tried save as a dwg file but it seems to be an Invnetor dwg which has the geometry as a block when opened with AutoCAD.  It is a little easier to explode the block in AutoCAD rather than open and extract the zip file, save the extracted dwg then delete the zip file.
3 REPLIES 3
rdyson
in reply to: Barry1Lau
In optons, uncheck pack and go if it's checked
If it's not checked, check it then uncheck it.
That's worked for me in the past.
(may require actually doing a save copy as between the checking and unchecking)
PDSU 2016
mrattray
Mike (not Matt) Rattray
Tags (1)
Barry1Lau
in reply to: mrattray
Thank you so much!  That was so much easier.  It really helped after the screen shots came in because I couldn't figure out which "options" were supposed to be accessed.
