I'm relatively new to Inventor and am trying to export a simple drawing as a 2d pdf. I have two requirement:
1. Save the piece at 1:1 scale (it is only 70mm x 31mm)
2. Save without the axes label that automatically shows up in the bottom left. I cannot have anything on the page besides my drawing.
Thanks very much for any help!
Solved by mcgyvr. Go to Solution.
Welcome to the group!
When you say drawing, do you mean a model? Are you trying to get a 2D PDF of a view of your model? If so, I don't know of any way to create a 1:1 output from the model screen. What method are you trying to use to create this PDF?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks very much.
I am trying to get a 2D PDF of my model. In fact, I am trying to get a .xps view of my 2d model. I do mean that I am using a model and I have tried a few options to save as a PDF including export as pdf and safe as pdf.
@agrzesik wrote:
Thanks very much.
You create a idw (drawing).. place views in it at 1:1 scale and print to PDF or xps printer at 1:1 scale..
