Solved by mcgyvr. Go to Solution.
Solved by blair. Go to Solution.
If you are worried about interior components, use the Shrink-Wrap if all they need is the exterior "shell". The only other way would be to do a Save-Copy-As and then delete the items you don't want to send. Then do either a Derive to IPT for a single part or send the "reduced" IAM file or export the"reduced" model to a neutral format such as IGES or STEP
Yep Shrinkwrap or Simplify tools..
