Inventor General Discussion
*Expert Elite*
LT.Rusty
Message 1 of 6 (242 Views)
Export to PDF doesn't automatically open the new PDF anymore?
242 Views, 5 Replies
01-07-2014 07:13 AM
Anyone else seeing this happen?  It started about 3 or 4 weeks ago on my office workstation with Inventor 2013 Pro.  Seems to still go okay at home with 2014.  I'm using Inventor's built-in PDF export, not an external program.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
*Expert Elite*
Curtis_Waguespack
Message 2 of 6 (239 Views)
Re: Export to PDF doesn't automatically open the new PDF anymore?
01-07-2014 07:20 AM in reply to: LT.Rusty
Hi LT.Rusty,
As odd as it sounds, this is controlled in the publish options of the DWF file.
Go to Export > Export to DWF and un-check the Display Published File in Viewer option found at the bottom of the General tab. This option controls the PDF viewer as well as the DWF. With this option unchecked the PDF will not open automatically after it is published.
related link:
http://inventortrenches.blogspot.com/2012/08/disable-automatic-pdf-display.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
LT.Rusty
Message 3 of 6 (235 Views)
01-07-2014 07:24 AM in reply to: Curtis_Waguespack
Right, but my problem is that I WANT the PDF to display - I almost always have to email a PDF once it's created, and I usually also have to save-as to at least one or two additional locations - and when I check the box for DWFx export it doesn't appear to be persistent.  It only works for that export of a DWFx, and if I come back again the box is unchecked again.
*Expert Elite*
Curtis_Waguespack
Message 4 of 6 (227 Views)
01-07-2014 07:36 AM in reply to: LT.Rusty
Hi LT.Rusty,
Sorry for the confusion, I pasted directly from the related link, which addressed disabling that option. But in your case you would want to enable it, as you mentioned.
As for the setting not persisting in the state that you set it to, I've not encounterd that sort of thing, other than when a crash/abnormal exit was encountered.
I do seem to recall others mentioning issues with settings not persisting in the past that were addressed in service packs / updates, so you might check to see if you have the latest installed:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?linkID=9242019&id=2334435&siteID=123112#section15
I hope this helps.
Curtis
pball
Message 5 of 6 (218 Views)
01-07-2014 07:54 AM in reply to: Curtis_Waguespack
Also whenever changing settings make sure to only have one instance of Inventor running.
*Expert Elite*
LT.Rusty
Message 6 of 6 (216 Views)
01-07-2014 08:00 AM in reply to: pball
Only one instance open, and I'm running SP2 Update 3.
Announcements
Need installation help?
