Inventor Forum
Export to Inventor Fusion
4 REPLIES 4
551 Views, 4 Replies
Can I open an autodesk inventor file in inventor fusion?
4 REPLIES 4
JDMather
Yes.
in reply to: JDMather
Thanks for the reply,
Just one more question is that a seamless compatiable format or or there should be some problems?
Does that mean any project created in Autodesk Inventor can be transformed into algor (Autodesk Simulation)?
JDMather
You can also use the Change Manager to have the Fusion features converted to Inventor features.
I recommend you search for Kevin Schneider free classes on Fusion here http://au.autodesk.com
JDMather
If you have Autodesk Simulation installed - you should have an icon in Inventor to go directly to "Algor" with your Inventor model or Fusion if you want to simplify it for analysis without changing the original.
Note: this image is of my Inventor screen
