Hi All,
This may be a customization question, but when I export to dwg in Inventor, everything appears on layer 0. Is there a way to map sketches and features from Inventor to defined layers in dwg?
I am interested in either of these two options, or both:
- From ipt: sketches and features (surfaces, solids etc.) to defined dwg layers
- From iam: parts to defined layers
I am using Inventor 2013.
Thank you,
Samu
When you insert the dwg file into sketch, the layers information from AutoCAD could be inserted. If the layer information is incorrect, please check the dwg trueview is installed correctly.
For the Asmebles, parts are unable to be defined layers as dwg shown, so it's unable to get the layer informatino.
