Inventor Forum
Export to dwg layers
1 REPLY 1
samu3
306 Views, 1 Reply
Hi All,
This may be a customization question, but when I export to dwg in Inventor, everything appears on layer 0. Is there a way to map sketches and features from Inventor to defined layers in dwg?
I am interested in either of these two options, or both:
- From ipt: sketches and features (surfaces, solids etc.) to defined dwg layers
- From iam: parts to defined layers
I am using Inventor 2013.
Thank you,
Samu
Tags (3)
1 REPLY 1
Yong.Jing
in reply to: samu3
When you insert the dwg file into sketch,  the layers information from AutoCAD could be inserted. If the layer information is incorrect, please check the dwg trueview is installed correctly.
For the Asmebles, parts are unable to be defined layers as dwg shown, so it's unable to get the layer informatino.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
