Inventor General Discussion
rthapa
Message 1 of 5 (1,249 Views)
EXPORT TO DWG ILOGIC RULE DOES NOT WORK
1249 Views, 4 Replies
01-05-2012 07:26 PM
Can someone help me out? I have a simple iLogic rule to save an IDW using SAVE COPY AS DWG. The rule was created in Inventor 2011 ilogic and was embeded in the IDW template. Trigger was set to activate when the new drawing file was saved. It no longer works and errors out in Inventor 2012. The template has been migrated to 2012 and so has the project file. The ilogic Code is given below. Can anyone help me out figure out the error or tell me if some new settings in Inventor 2012 need to be changed for it to work? Or if you have an ilogic rule to do the same that works, perhaps you can post in an answer to me. '------- start of iLogic code ------------------- ' Get the DWG translator Add-In. Dim DWGAddIn As TranslatorAddIn DWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\temp\DWGout.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name oDataMedium.FileName = "C:\" & ThisDoc.FileName() & ".DWG" DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the DWG file in whatever application Windows is set to open this document type with i = MessageBox.Show("Preview the DWG file?", "Title",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName) '------- end of iLogic code -------------------
Hi Rthapa,
Your iLogic code works. I tried the following steps.
  1. Start inventor 2012.
  2. New an idw and save it
  3. Create a ilogic rule.
  4. Paste the ilogic code (in the diagnosis window) to the code window.
  5. Make sure the C:\temp\DWGout.ini exist.
  6. Run the rule.
Result: The dwg can be generated correctly.
Can you verify if the ini file ("C:\temp\DWGout.ini"  )  referenced in your code exist? Expection will be thrown if it doesn't exist.
If the problem still exists on your build, could you upload a problematic idw with the rule and the screenshot for the error message? It will help a lot to triage the issue.
You have created this thread twice now.
Please add your comments to the original forum request.
Jon.
Product Support
jon.dean
Message 2 of 5 (1,224 Views)
Re: EXPORT TO DWG ILOGIC RULE DOES NOT WORK
01-09-2012 07:11 AM in reply to: rthapa
I had another customer with a similar problem and I logged the issue with development.
I am still waiting for them to update me.
I think the problem is the Add-in ID but I am not 100% sure.
Jon Dean
Employee
jeffrey.sun
Message 3 of 5 (1,212 Views)
01-09-2012 07:35 PM in reply to: rthapa
Hi Rthapa,
  6. Run the rule.
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
Product Support
jon.dean
Message 4 of 5 (1,191 Views)
01-10-2012 03:31 AM in reply to: jeffrey.sun
Jon.
Jon Dean
rthapa
Message 5 of 5 (1,179 Views)
01-10-2012 06:56 AM in reply to: jeffrey.sun
Hi Jeffrey.Sun,
You are awesome.  Your suggestion worked.
My original IDW template was migrated from Inventor 2011 to Inventor 2012 with the rules already embeded.
With your suggestion, I created a new blank IDW template with no rules then added the same old rule in it. It works like a charm now.
Somehow migrating old template was failing.
Yeh! Off to the races.
Raj
