The BMP is not refine enough to perform simple graphic editing. Any
> way to do this?
I have tried the Save to Jpeg from Cbliss, it is a
> idw save to jpeg. Which is not good enough.
The other way is to
> import the model into 3DSMAX and render again. Which is an overkill.
Anyone has been through this? Please share your experience! Thanks!
Francis Attachment decoded: untitled-1.htm
When you save as bmp, are you setting the resolution high enough? Under
options you can set the x and y resolution. Set the x resolution at
whatever you want and the y will take care of itself. Just leave it at
zero. Then in your graphics software you should be able to take the
resulting high-res bmp and save as png.
HTH
J
Error in UNIVERSE.EXE; cannot find REALITY.SYS. Program terminated.
