Inventor General Discussion
Distinguished Contributor
0 Kudos
Post 1 of 16
Export/Importing STL files Inventor Pro 2012
6725 Views, 15 Replies
12-28-2012 06:29 PM
A couple months ago I could export to STL files using Inventor Pro 2012 and a third party could open them on whatever platform they are using. Now when I export to STL files, the third party cannot open them and I cannot open them either on the Inventor Pro 2012 platform. Nothing has changed since the originals were sent to the third party. I have read some of the threads, but there is a lot of STL, none of the ones I read address this problem. The properties from Windows Explorer say the file type is Certificate Trust List (.stl).
773 Kudos
Post 2 of 16
Re: Export/Importing STL files Inventor Pro 2012
12-29-2012 11:10 AM in reply to: jrm_1971
Possibly if you are trying to open the STL files from the Windows Explorer, it doesn't know what program is used to open the STL file. Can you open from within Inventor. I have no problems here either exporting Inventor to STL or importing STL files.
If you wish to open STL files from the Windows Explorer window, you would need to RMB click on the file, select Open With, and then navigate to where the Inventor.Exe file is located.
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
2,122 Kudos
Post 3 of 16
12-29-2012 02:28 PM in reply to: jrm_1971
Create a 1mx1mx1m cube and and then Save Copy As type STL.
Attach both the ipt and the stl file here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
773 Kudos
Post 4 of 16
12-29-2012 03:48 PM in reply to: jrm_1971
Try opening this one, it works fine on my system at home
Win7-64
Delta Tau Chi ΔΤΧ
0 Kudos
Post 5 of 16
12-31-2012 02:34 PM in reply to: blair
Nope, exporting and opening in Inventor Pro 2012. It just mysteriously started doing this.
0 Kudos
Post 6 of 16
12-31-2012 02:37 PM in reply to: JDMather
STL file attached cube
773 Kudos
Post 7 of 16
12-31-2012 03:11 PM in reply to: jrm_1971
I am able to ope the cube file here. I'm not on IV2012 though. Are you current on all the SP's and hot-fixes.
Win7-64
Delta Tau Chi ΔΤΧ
2 Kudos
Post 8 of 16
01-01-2013 03:06 AM in reply to: jrm_1971
I wonder if one could open the stl files in the Inventor 2012 environment.  I could not find the stl file type in the drop down list.
773 Kudos
Post 9 of 16
01-01-2013 09:30 AM in reply to: luiww
There is no specific STL extension, just use the (*.*) option to allow you to open any file.
Win7-64
Delta Tau Chi ΔΤΧ
2 Kudos
Post 10 of 16
01-02-2013 05:03 AM in reply to: jrm_1971
I tried and obtained a message "Failed to open document".  I am not able to attach the stl file here owing to its file type.
