Hi:
My name is Luis need to know if you can helpme with this. I need some help about exporting to excel Features Names and Consumed Parameters of a part. That information is actually used for part manufacturing-route sheet. As I can see in Part Parameters Window, every parameter is consumed by an feature so I want to re-use that information in an Excell SpreadSheet.
by example:
Extrusion1(50mm (d2)) has consumed sketch1, (sketch1 has one circle diameter 20mm(d1))
Extrusion2(50mm (d4)) has consumed sketch2, (sketch2 has one circle diameter 30mm(d3))
so I need to export parameters:
Extrusion 1 < feature name
-d1 =20 <parameter consumed
-d2 =50 <parameter consumed
Extrusion 2 < feature name
-d3 =30 <parameter consumed
-d4 =50 <parameter consumed
You can do it, and it's not that difficult, but you'll need to use iLogic to do it.
You'll probably wind up using a combination of the following commands in some sequence:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 915 StartFragment: 314 EndFragment: 883 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
GoExcel.Open("filename.xls", "Sheet1")
This will open a file and set Sheet1 as the active sheet.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 1230 StartFragment: 314 EndFragment: 1198 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
GoExcel.CellValues("filename.xls", "Sheet1", "A2", "A10")
This will write data to the specified location in Sheet1 of the opened file.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 518 StartFragment: 314 EndFragment: 486 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
GoExcel.Save
This will save your file.
You'll have a few other things in there as well, but these will probably be the ones that you use the most.
Rusty
Hi! Indeed, iLogic will help you collect the data more easily. You can simply create a dummy rule and then right-click in the model tab (in iLogic dialog) -> Capture Current State. Then all the features and associated parameters will be captured in the rule.
Thanks!
Hi, im really sorry but I Cant get with the correct program with ilogic, need training on it pretty much, because I dont know about programming. So can you help me with this? thank you.
