Hello to everybody,
I would like to export stress data for each node of my FEM in a report file, is it possible? What is the most efficient way to do it? I must, furthermore, postpro the data in an Excel spreadsheet, a .txt format would be the perfect solution to accomplish this type of operation.
Thank you for your attention,
Best regards.
Francesco
Solved by admaiora. Go to Solution.
Hi Francesco,
no, you can't do that.
In FEA you can't export results related nodes, you can only report with the "Report" tool.
You can report in .html or in a text file (.rtf)
Alternatively you can interrogate the model in points using the "Probe" tool
Admaiora
