In Inventor 2013 when i export face as it is automaticly exported to DWG 2013 version. How to i set it to 2010 version export without having to do it everytime manually? (option then chooose 2010)
From the DXF file export Options dialog, select AutoCAD 2010 DXF and any other options you wish to and then save the configuration to your current project folder.
Inventor should pick up the configuration automatically from then on.
I hope that is what you wanted, because you state DXF in the subject, but DWG in the post?????
Either way, the steps are the same except for selecting dwg instead of dxf.
Thanks, I only mean DXF. I only had to choose custom config and it worked.
