Is there a way to create stp files of all my 2014 Inventor files for a project without opening up each file and then exporting it as a stp file?
Solved by JDMather. Go to Solution.
I have never used this before - but have you investigated the functionality of the Task Scheduler?
Start>All Programs>Autodesk>Inventor>Tools
JD,
It worked like a charm!!!! I just exported more than 150 Inventor .ipt and .iam files as .stp files while I happily watch the Bears instead of openning a file and saving as stp, etc, etc......etc.Thank you so much!!
I've been saying this for years and I will say it again. The help an independant solo operration like mine gets from the other users of this forum makes it possible to use this efficiently software to make a living.
Again, thank you so much.
Ed
how do i do that with iPart files? (each .ipt file has 10 members for example)
Hi. You can save each iPart file individually as a .ipt by right clicking on each one anf selecting 'generate files'. Then proceed to do as above ^
