I want to export a pdf file when saving my drawings, but I want the pdf file on a diffierent engineering drive. I found this code but don't know where to place my file path. Sorry trying to learn iLogic.
2014 Inventor Professional.
'------start of iLogic-------
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
'step through each drawing sheet
For Each oSheet In oDrawing.Sheets
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos -1)
'find the sheet number
iSheetNumber = Right(oSheet.Name, sLen -lPos)
'set PDF Options
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = iSheetNumber
oOptions.Value("Custom_End_Sheet") = iSheetNumber
End If
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & " " & sSheetName & " " & iSheetNumber & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Next
Solved by Curtis_Waguespack. Go to Solution.
Hi rlester,
You should be able to change:
to:
oFolder = "Q:\Temp\MyFolder\Engineering\PDF Folder"
Where "Q:\Temp\MyFolder\Engineering\PDF Folder" is the folder path that you want the PDFs to be saved to.
I hope this helps.
Curtis
Thanks a million that worked great. Maybe someday I will understand how to read iLogic.
Thanks again.
FYI, since you're trying to learn iLogic:
The original version of the code you posted looks for the folder location of the drawing file, then puts the PDF in a subfolder (named PDF).
Example:
If the drawing is located in C:\Drawings,
PDF will be located in C:\Drawings\PDF
That is why that line of code looked so much more complicated, and is one reason why you didn't immediately see a place to change the save path. The original code isn't given a path - it finds the path on its own based on the location of the Inventor drawing.
Thanks for the FYI, that makes sense. Anything that I can learn will help in the future.
Really appreciate the quick response and the help.
