Anyone has seen this thing?
2d drawing , export or save copy as > Dwg (AutoCAD)
It happens only with some bolts (especially exagonal), the "wrong segments" are splines.
I don't have the dwg at the moment, so i can't reproduce de issue.
Any ideas?
Thank you!
Admaiora
Solved by Jon.Dean. Go to Solution.
Please post the source Inventor drawing if possible. We need to reproduce the bad export in our internal builds to see what's going wrong there.
Oto
Hello Oto,
thank you.
I don't have the file at the moment, i hope i will have it soon.
Meanwhile...anyone has seen something like this?
Admaiora
There was a problem with spline export; See if changing the spline export option fixes it:
i wil test it, meanwhile..thank you Adrian!
Admaiora
It didn't work.
Here a video.
And the file.
In the first part with no SP (with the issue)
In the second part with SP (with no issue).
At the moment it's not possible to install the SP.
Was it a known issue?
Is it possible to solve with no SP?
Admaiora
Take a look at the following solution:
Hope it helps.
Jon.
It didn't solve the solution.
I didn't accept as solution.
And it was already posted by Salariua.
Admaiora
