Show only
Search instead for
Export assembly drawing to .dwg with parts as blocks
Hi I was wondering if there is a way to export or save an assembly drawing to .dwg format (that can be opened by acad or acad mechanical) in such a way that all the parts of the assembly are exported as individual blocks (within the same file) To explain- lets say I have a .iam out of which I create a drawing (.dwg for inventor). Then I export or save this as acad dwg. This acad dwg should have all parts of the assemblies as blocks so that if I want to work on a particular part in the 2d environment of acad, that is possible.
