Inventor General Discussion
Valued Mentor
hardin
Message 1 of 7 (667 Views)
Export ADSK file
667 Views, 6 Replies
05-17-2012 03:44 PM
I'm trying to find a good way to bring Inventor Assemblies into Revit Structure.
In 2013, I don't see an ADSK export feature. Does it still exist? It's never worked for me in the past, but I keep trying with each version....
Valued Mentor
hardin
Message 2 of 7 (662 Views)
Re: Export ADSK file
05-17-2012 05:01 PM in reply to: hardin
I found it under BIM export. Funny the Help file turns up nothing when searching for ADSK...
Employee
patrick.miller
Message 3 of 7 (645 Views)
05-18-2012 06:05 AM in reply to: hardin
Hi hardin,
May I ask where you were searching for help content? If I search the WikiHelp for adsk or export adsk, BIM Exchange is in the top 10 for both. I ask because we (Autodesk) are trying to better understand how customers are searching for help especially when they are NOT finding what they need.
Thanks much.
Patrick Miller
Senior Content Developer
Autodesk, Inc.
*Pro
jletcher
Message 4 of 7 (641 Views)
05-18-2012 06:17 AM in reply to: patrick.miller
Back in the day the help was real help now thumbs down. I don't even have help. If I hit the help tells me there is no help file don't know the whole error but I did go look for the file and it was there.
Autodesk I don't know what you are doing with my Inventor but I think you need to step back and see that some or most  end users are not happy with a lot of things you are doing. Do we not matter to you any more?
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Mentor
hardin
Message 5 of 7 (634 Views)
05-18-2012 07:05 AM in reply to: patrick.miller
I can't get a license right now, but I was in Inventor 2013. I typed in ADSK in the space at the top of the screen above the ribbon. Nothing was found for ADSK. Same with wikihelp... I think. If I can get a license later today, I'll revisit that and let you know.
Thanks for the reply and helping out.
Lyle.
Valued Mentor
Mason-Paul
Message 6 of 7 (624 Views)
05-18-2012 12:10 PM in reply to: hardin
Typing in ADSK worked for me
BUT why do these technocrats have to use hundreds of words, with in the instructions hidden among them for good measure, to confuse people, when in some or most cases simple screen shot would suffice and save confusion and annoyed users.
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Employee
patrick.miller
Message 7 of 7 (621 Views)
05-18-2012 12:48 PM in reply to: Mason-Paul
hardin (Lyle): In 2013, the search box in the title bar will take you to the WikiHelp, so it should be the same as what I saw. You don't need an Inventor license, you can go to http://wikihelp.autodesk.com at any time. Also the words adsk and adsk export in my previous post are hyperlinks to their respective searches.
jletcher: What version of Inventor are you using? Inv 2012 and 2013 should default to the WikiHelp and not a local file. If you do not have internet access, you are directed to a smaller, local file. If you could tell me your version and the error message, I might be able to help.
Mason-Paul: your comment is something we are working to improve. We understand that the procedures and references became buried when we moved to the wiki. We plan to make the procedures and references much more descoverable but will still have the technocrat info available for those interested.
Patrick
Patrick Miller
Autodesk, Inc.
Post to the Community
New Post
Need installation help?
