I am setting up an exploded view of an assembly. If I have the assembly explode automatically the parts explode into different directions. the assembly also does similar in the manual mode when tweaking components; only not as bad. Has anyone ran into this and what is the issue with my assembly that causes this.
Thank,
Tim
All depends on your assembly constraints.
Automatic really only works for a "stack of pancakes" type assembly.
I always manually tweak the parts.
It takes some advanced planning or you end up just starting over.
This area hasn't seen any development that I can recall in many many years.
