Inventor General Discussion
Valued Contributor
gregmcl
Message 1 of 2 (267 Views)
Explode Text to Sketch
267 Views, 1 Replies
10-01-2012 11:50 PM
Is it possible to convert Text to a sketch in which I can edit individual letters. I want to use the text as a profile path for a plasma cutter. I tried Emboss, but Letters with islands in them, completely cut the letter out. I want to be able to add a bridge for one of a better word, by editing a sketch. Any Suggestion Welcome.
Regards
Greg
The only fast way is to dxf or dwg out your part and insert it into autocad to and tabs to the letters. Inventor does not use regular text it uses a bitmap for text so there is really good way to do it in just Inventor.
The really only way to do it in Inventor is to add the tabs with extrude. Not the fastest way. Look at sample.
*Pro
jletcher
Message 2 of 2 (249 Views)
Re: Explode Text to Sketch
10-02-2012 04:33 AM in reply to: gregmcl
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
