Pls let me know how would i explode the block in inventor.
Modification of a block is no problem, Bt i want to explode a block, In stead os same 4 block i have to change 1 only by exploding..So Is there any command to explode a 1 block out of 4?
Solved by JDMather. Go to Solution.
Can you explain what you mean by a block? Are you working in a part environment, assembly or drawing? Maybe a picture of what you are trying to change? A "block" is more of an Autocad term for a group of 2D entities tied together to make a symbol or something similar.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Simply right click on the block you want to explode and select Explode.
Thanks JD... I never think of sketch blocks... never used them.
Chris Benner
