Inventor Forum
expanded metal, how to create it?
12 REPLIES 12
Message 1 of 13
825 Views, 12 Replies
I would like to know if anyone has successfully made a model of Expanded
Metal Mesh?
I thought that I saw a post here or ICF the other day but I believe it was a
cylinder and not a flat piece, now I can't find it. With the type of work I
do it would be nice if I could use the Expanded Metal in some of my
assembly's.
Josh
12 REPLIES 12
Message 2 of 13
Won't a texture with transparency do?
"Josh Beissel" wrote in message
news:4098754A63DC993E940173A21612C9C9@in.WebX.maYIadrTaRb...
> Hi,
> Metal Mesh?
a
I
> assembly's.
> Thanks
> Josh
Message 3 of 13
You can use the expanded metal texture to show expanded metal. Use
Format>Colors>Texture>Choose and select the expanded metal texture. See my
post on 10/2/2003 titled "Expanded Metal Guard" for an example.
> Hi,
> Metal Mesh?
a
I
> assembly's.
> Thanks
> Josh
Message 4 of 13
Most of us use a texture. To actually model the mesh would use way too
much resources. Checkout FAQ0416 at www.mymcad.com
Josh Beissel wrote:
> Hi,
> Metal Mesh?
> assembly's.
> Thanks
> Josh
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
Message 5 of 13
Thanks Guys I'll have to try using the textures like you had said.
"Hal Gwin" wrote in message
news:33A7D580D2A4E9333724688548C4BB10@in.WebX.maYIadrTaRb...
> Josh Beissel wrote:
> > Hi,
Expanded
> > Metal Mesh?
was a
work I
> > assembly's.
> > Thanks
> > Josh
> Hal Gwin
> Mechanical Designer
> Xenogen
> W2K SP4
> Dell Precision 650
> Dual 2.66 GHz Xeon
> 1.5 GB DDR
> Quadro4 900 XGL
Message 6 of 13
There is another Expanded Mesh texture on:
http://www.cbliss.com/inventor/Textures/default.htm
>>Josh Beissel wrote:
>>>Hi,
>Expanded
>>>Metal Mesh?
>was a
>work I
>>>assembly's.
>>>Thanks
>>>Josh
>>Hal Gwin
>>Mechanical Designer
>>Xenogen
>>W2K SP4
>>Dell Precision 650
>>Dual 2.66 GHz Xeon
>>1.5 GB DDR
>>Quadro4 900 XGL
Message 7 of 13
Think the link got whacked on your Engine Turning and Cast Iron textures.
~Larry
"Charles Bliss" wrote in message
news:543A9F658AFBD20358018BA0EF1E71EC@in.WebX.maYIadrTaRb...
> >>Josh Beissel wrote:
> >>>Hi,
> >Expanded
> >>>Metal Mesh?
> >was a
> >work I
> >>>assembly's.
> >>>Thanks
> >>>Josh
> >>Hal Gwin
> >>Mechanical Designer
> >>Xenogen
> >>W2K SP4
> >>Dell Precision 650
> >>Dual 2.66 GHz Xeon
> >>1.5 GB DDR
> >>Quadro4 900 XGL
Message 8 of 13
Thanks I never thought to check out Charles' site. I've found a lot of
useful things there in the past. I even picked up a couple of extra texture
when I stopped in.
Thanks guys,
Josh
"Larry Caldwell" wrote in message
news:AC50E9475FAD3FA76A1767340FE3F52F@in.WebX.maYIadrTaRb...
> ~Larry
too
> > >>Josh Beissel wrote:
> > >>>Hi,
> > >Expanded
> > >>>Metal Mesh?
it
> > >was a
> > >work I
> > >>>assembly's.
> > >>>Thanks
> > >>>Josh
> > >>Hal Gwin
> > >>Mechanical Designer
> > >>Xenogen
> > >>W2K SP4
> > >>Dell Precision 650
> > >>Dual 2.66 GHz Xeon
> > >>1.5 GB DDR
> > >>Quadro4 900 XGL
Message 9 of 13
Now that I have the new textures how do I get them into the texture library?
I'm not to sure how to do it.
news:0879F9799894A2165BEA6261E7FE9B5D@in.WebX.maYIadrTaRb...
texture
> when I stopped in.
> Thanks guys,
> Josh
textures.
> > ~Larry
> too
> > > >>Josh Beissel wrote:
> > > >>>Hi,
> > > >Expanded
> > > >>>Metal Mesh?
> it
> > > >was a
of
> > > >work I
> > > >>>assembly's.
> > > >>>Thanks
> > > >>>Josh
> > > >>Hal Gwin
> > > >>Mechanical Designer
> > > >>Xenogen
> > > >>W2K SP4
> > > >>Dell Precision 650
> > > >>Dual 2.66 GHz Xeon
> > > >>1.5 GB DDR
> > > >>Quadro4 900 XGL
Message 10 of 13
Forget my last question. I got it taken care of, just copied the texture
then added it to the Inventor texture folder.
Josh
news:CDDB1246D39787E959BE5B95B30D02E4@in.WebX.maYIadrTaRb...
library?
> texture
> > when I stopped in.
> > Thanks guys,
> > Josh
> textures.
> > > ~Larry
way
> > too
> > > > >>Josh Beissel wrote:
> > > > >>>Hi,
> > > > >Expanded
> > > > >>>Metal Mesh?
believe
> > it
> > > > >was a
type
> of
> > > > >work I
my
> > > > >>>assembly's.
> > > > >>>Thanks
> > > > >>>Josh
> > > > >>Hal Gwin
> > > > >>Mechanical Designer
> > > > >>Xenogen
> > > > >>W2K SP4
> > > > >>Dell Precision 650
> > > > >>Dual 2.66 GHz Xeon
> > > > >>1.5 GB DDR
> > > > >>Quadro4 900 XGL
Message 11 of 13
I decided to make expanded metal the lesson of the day, see files in
IVCF. Regular and flattened are there. There are 4 parameters (thanks
Larry) that drive the basic shape. Then array that shape into the
approximate size you need or array it to the standard 4' x 8' size. In
a couple of days when the array is finished.... you can cut the shape
you need from it.
On Thu, 20 Nov 2003 13:26:51 -0800, "Josh Beissel"
wrote:
>Hi,
>Metal Mesh?
>assembly's.
Message 12 of 13
Now that's what I was talking about earlier, the real deal not just a
texture. Both will work out great for my applications.
Thanks to all of you for the good suggestions and work you did.
Josh
wrote in message
news:palsrvon75tj1apk0sinbs2qik832kcsj6@4ax.com...
> you need from it.
> wrote:
> >Hi,
> >Metal Mesh?
was a
work I
> >assembly's.
Message 13 of 13
Thanks! That helped me too.
Jim S.
news:E5EF4B6135237B05195B4D824138F985@in.WebX.maYIadrTaRb...
> Josh
> wrote in message
> > you need from it.
> > wrote:
> > >Hi,
Expanded
> > >Metal Mesh?
> was a
> work I
> > >assembly's.
