Now that's what I was talking about earlier, the real deal not just a
texture. Both will work out great for my applications.
Thanks to all of you for the good suggestions and work you did.
Josh
wrote in message
news:palsrvon75tj1apk0sinbs2qik832kcsj6@4ax.com...
> I decided to make expanded metal the lesson of the day, see files in
> IVCF. Regular and flattened are there. There are 4 parameters (thanks
> Larry) that drive the basic shape. Then array that shape into the
> approximate size you need or array it to the standard 4' x 8' size. In
> a couple of days when the array is finished.... you can cut the shape
> you need from it.
> On Thu, 20 Nov 2003 13:26:51 -0800, "Josh Beissel"
> wrote:
> >Hi,
> > I would like to know if anyone has successfully made a model of Expanded
> >Metal Mesh?
> >I thought that I saw a post here or ICF the other day but I believe it
was a
> >cylinder and not a flat piece, now I can't find it. With the type of
work I
> >do it would be nice if I could use the Expanded Metal in some of my
> >assembly's.
