Inventor General Discussion
Valued Contributor
timdown73
Message 1 of 11 (466 Views)
Expand the constraint window
466 Views, 10 Replies
12-18-2012 11:57 AM
Is there a way to expand the constraint window so that I can see my entire parameter formula?  In the image below, my equation is cut off in the "offset" window.  Or am I supposed to be inputting the parameters in some other manner?
This is by designed within the product I think. If you would like to enter a wish list item asking for this to be considered as an enhancement please use the following link.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Submit the possibility to expand this dialog box like any other windows ones.
Don
JDMather
Message 2 of 11 (448 Views)
Re: Expand the constraint window
12-18-2012 02:59 PM in reply to: timdown73
Can you create a named parameter with a short name and make it equal to the equation you entered?
Then you would only need to enter the short name. (or click the arrow at the end of the box and select Show Parameters and then select it from list of user named parameters.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
timdown73
Message 3 of 11 (413 Views)
12-19-2012 05:23 AM in reply to: JDMather
Thanks for the reply.  I take it there is no way to expand the constraint dialog box.  That's really what I want to do and I wanted to make sure there isn't a way to do it before I post about it in the Inventor IdeaStaition. Maybe it's me but I run into this all the time...Even if you use shorter names, if you put 3 or 4 parameters in, it's impossible to see them all.
jtylerbc
Message 4 of 11 (407 Views)
12-19-2012 05:43 AM in reply to: timdown73
No, there's really no way to expand that box, but there is a workaround.  You could try this (which is what I do when a formula is too long to work with in a dialog box):
Name the parameter and give it a temporary value in the constraint dialog box by typing it in using the "Equal" shortcut.
ex.  "WIDTH = 5 in"
This is so you will be able to recognize the parameter easily in the next step.
Then open up the Parameters dialog box (on the Manage tab), and write your formula in there, replacing the temporary number you gave it earlier.  This dialog box typically has larger columns for the formula than the normal command dialog boxes to begin with, AND can be resized to be even larger.
John Tyler
Inventor 2015
Windows 7 64 Bit
Valued Contributor
timdown73
Message 5 of 11 (384 Views)
12-19-2012 10:36 AM in reply to: jtylerbc
Thanks for the reply.  I can see that working well for model parameters but I use a lot of User parameters that are established before I even start a sketch.  I abbreviate as much as I can but that darn window is so small.  I don't see why they can't make it expandable.
jtylerbc
Message 6 of 11 (367 Views)
12-19-2012 12:28 PM in reply to: timdown73
Not sure I'm following how User Parameters would be a problem for this method - this is the same dialog box where you would have created them, so it should work fine for them, unless I'm missing something about what you're doing.  They should all be listed in the User Parameters section toward the bottom of the Parameters dialog box.
Having that box be expandable into a larger equation-editing box wouldn't be a bad thing though.  Could even be as simple as just taking you directly to the Parameters dialog box with the relevant row highlighted.
John Tyler
Inventor 2015
Windows 7 64 Bit
blair
Message 7 of 11 (362 Views)
12-19-2012 12:51 PM in reply to: jtylerbc
You can always set up a part template with the common parameters (formula) in the template.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
Product Support
4donwan4
Message 8 of 11 (309 Views)
12-26-2012 10:13 AM in reply to: timdown73
Don
Valued Contributor
timdown73
Message 9 of 11 (277 Views)
01-02-2013 05:28 AM in reply to: 4donwan4
Thank you Don.
Active Contributor
IS200
Message 10 of 11 (249 Views)
01-02-2013 06:10 PM in reply to: timdown73
I have submitted this exact scenario as a wishlist item at least 5 times in the past and nothing comes of it. It's not only the constraint dialog box, have you ever tried to do a pack & go? An assembly may have 100 parts or more but the bottom dialog lets you see 4 of them at a time, really handy, not!
I think Autodesk should employ a consultant who actually uses the software on a daily basis to give some real-world advice on making this program properly user friendly.
The last 3 releases have provided more and more eye-candy, which does not make the program any better from a designer's point of view, and all the important fixes are being left by the wayside.
Autodesk, it's time to stop fighting the eye-candy war against your competitors and give the end user some improvements which make their day to day jobs better and easier.
