Inventor Forum
EXISTING INVENTOR FILES WILL NOT OPEN IN SAME VERSION
5 REPLIES 5
357 Views, 5 Replies
Existing Inventor files will not open in the same version of Inventor in which they were created on the same pc.
The error message reads 'database schema is newer than this version of software'
A sample file is attached. Is there an answer to this other than having an expensive upgrade???
5 REPLIES 5
ampster401
knowing what version you are using would help.
THE VERSION WE ARE USING IS 2011 - Does this make a difference? We have never used a later version to create files.
harco
We're on 2011 and it opened fine here.
Ryan.Martinez
Try a repair install/reinstall?
P.D.S. 2015
P.D.S. 2016
ampster401
Since you provided a file for others to download and attempt to open...
Think about it...
If I'm on 2010, why should I waste my time and download your file just to see the same msg you are getting?
Does that help you?
That's the reason I won't bother downloading anything unless the version is stated.
Yes, it makes a difference.
http://forums.autodesk.com/t5/Autodesk-Inventor/For-the-new-guy-s-in-the-discussion-group/m-p/3636464#M449277
I for one avoid the sig line.  If I have a question I'll post what version I'm using at the time I post the question.
