Inventor Forum
Excel parameters - disable parts
3 REPLIES 3
1018 Views, 3 Replies
Hi there,
I have linked my inventor drawing to excel to adjust some parameters. Is it also possible to have a enable/disable function in excel so a part in an assembly can be disabled at will?
Thanks in advance!
3 REPLIES 3
which version of Inventor do you use?
If you have ilogic on board you can solve it by using a specific value in your excel.
If value_x=1 then suppress feature y
You only need a trigger to give inventor the start sign.
Best Regards
Passi
Thanks for the reply,
I use the lastest version, 2012 SP1, only i never worked with iparts.
I tried to 'add rule' and then inserted this
If value_x=0 Then suppress Component.IsActive("part") = True
But this generates errors (not english)
translated:
Error on Line 1: The name was not suppress declared.
Error on Line 1: Method arguments must be enclosed in brackets.
I hope you don't insert the code example that way, it was only a text for describing what I mean and not a correct syntax 😉
I thinked about it and i think, I'ts not possible to create it via ilogic, because in my opinion you have to create a single LOD  for each variant. But I will think about it later on 🙂
So it's better to create it via VBA.
This is a example for Suppressing a part in an assembly, if you know the correct name and folder of the part you want to suppress: In this case it's the part "flange.ipt" in "c:\"
Public Sub Suppress()
    Dim AssemblyDoc As AssemblyDocument
    Set AssemblyDoc = ThisApplication.ActiveDocument
    Dim AssemblyDef As AssemblyComponentDefinition
    Set AssemblyDef = AssemblyDoc.ComponentDefinition
    On Error GoTo Error1:
    Dim SearchPart As Document
    Set SearchPart = ThisApplication.Documents.ItemByName("C:\flange.ipt")
    Dim SearchPartOccurrence As ComponentOccurrencesEnumerator
    Set SearchPartOccurrence = AssemblyDef.Occurrences.AllReferencedOccurrences(SearchPart)
    Dim OccurrenceOfSearchPart As ComponentOccurrence
    For Each OccurrenceOfSearchPart In SearchPartOccurrence
OccurrenceOfSearchPart.Suppress True
Next Error1: End Sub
Then Inventor will create a LOD by it's own. But you have to execute the Macro to create the changes. Or you create a start for the macro by open the assembly doc.
