As everybody know copy/paste excel file into an inventor drawing is sometimes difficult. As you can see in the printscreen a special character is not converted. I supposed it's because this special character is not in the AIGDT or is in the extended character set wich is not considered in Inventor?
It would be a good wish if this type of basic operation could be done
Hello Thomas,
perhaps you could check if the char is featured in the font Inventor is using.
If it´s not part of the font it might be possible to change to a font which features
the char you need.
Kind regards
Daniel
Thomas,
A better handshake between Autodesk and office products would help this. You can always suggest this in the Inventor IdeaStation. This also speaks to if the general tables had greater functionality like Excel this could help as well.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
