Single-Sheet Excel File comes in as 3 lines???
Used the General Table command.
Data starts at B2.
Any ideas anyone?
I always just select/copy the excel data and use "paste special"..
I find the general table command to be...well.. to general 🙂
Hi marshallw,
I'm fairly certain that you can not have any blank rows in your Excel file, as that signals the importer to stop at that line. I would encourage you to test that, by removing the empty rows and trying to insert it again, just to verify that I am not remembering incorrectly.
I hope this helps.
Curtis
You are correct. No empty rows you can put a " - " in the empty places...
