I know INV does this and I suppose I could dig to find it...
...but asking here is so much easier than digging.
There are times when I would like to define the viewing poing of the model exactly...
...say 48 inches off the floor and 120 inches away from the front face of an assembly.
Further, I'd like to define the viewing perspective as a function of the type of camera lens being used, say: 55mm or 135mm.
Can anyone point to those settings?
Thanks!
Solved by rdyson. Go to Solution.
You can probably get close enough in Studio. You may need to create a dummy part to use to position the camera where you want.
