It is an IE patch. If you are running NT you might also try this patch:
http://download.microsoft.com/download/c/c/8/cc8a7962-f72f-4358-a13d-326be29d3623/HHUPD.EXE
it updates the HTML Help application that is used to run the help system. I
have also heard that installing IE6 SP1 has fixed the problem for some
users. You might also try patch Q828750 based on Kirk A.'s posting on
10/28/2003. I hope this helps.
Ashley Rutherford
Autodesk DSS Developer
"Cliff Middleton"
wrote in message
news:66D4CBD43F9637AAB02B90A129A5FE60@in.WebX.maYIadrTaRb...
> Ashley,
> Is that a patch for IE or IV? I've tried (I think) all the IE updates
> (running NT4, by the way) and still have the plague.
> Cliff
> "Ashley Rutherford" wrote in message
> news:A4CA9CE4415AA225F4C1CD84F3A07944@in.WebX.maYIadrTaRb...
> > Has anyone installed patch 811630? If so, has it fixed the problem?
> > Ashley Rutherford
> > DSS Developer
> > "Brian R. Iwaskewycz" wrote in message
> > news:04BEFF2CA6FDC040421DD3698B6CE9D0@in.WebX.maYIadrTaRb...
> > > Perhaps try repairing Internet Exploder? The error isn't generated by
> > > Inventor, it's generated by IE.
> > > I figured you were using IE4.0 or 5.0. I've seen that before with
older
> > > versions of IE.
> > > "Kirk A." wrote in message
> > > news:8F137003D1756ED817F82805A84DC80C@in.WebX.maYIadrTaRb...
message
> > > > news:6FBB0850CE996D711CE6C8C2F6F609C3@in.WebX.maYIadrTaRb...
> > > > > What version of Internet Exploder are you using?
> > > > > news:DFB03EB4B356012369B28A1FD811A959@in.WebX.maYIadrTaRb...
> > > > > > When I start the Hellp and click on "Getting Started", I get
this
> > > error.
> > > > > I
> > > > > > tried doing a "Repair", but still have the same problem.
> > > > > > Any ideas?
> > > > > > Inventor 7.0 sp1+IDWperf
> > > > > > Dell 4550
> > > > > > WinXP Pro
> > > > > > P4, 2.8 Ghz, 1G
> > > > > > Quadro 900 XGL
> > > > > > nVidia v6.14.10.4403
> > > > > > 1280x1024, 32 bit
