hello:
when im trying to shell i need my wall to be .125in or .25in but i keep getting this error i went as high as 5in and as low as .001in just to see if it would keep giving me this error and it did if you can help me out im not sure what im doing wrong
Two things that will help you get an answer in the future:
- Post the file with your question, and give Inventor version used to create it
- Make the subject line much more descriptive (this will also help others searching for the same issue). For example "Shell Error: Non-Manifold Inputs, IV2011"
Please post the file, along with the Inventor version you are using.
Hi! Could you attach the file here or send it to me via email? The error message alone is not enough for me to tell where the problem is.
Thanks!
