Hi guys,
I'm having this error every time i print files on inventor.
Please help, many thanks.
Solved by blair. Go to Solution.
Can you print to that printer with other software on your system? Inventor uses standard Windows Printing convention. Check that your paper settings match that of your printer. I would also check that you have current printer drivers for your printer.
Try chaning the User Log-In and see if that works. If so you could have a corrupt user account with is easly fixed. Try using the Administrator account.
What was solution?
You should be able to set them to Admin at the local level on the PC and not at the network log-in level and it will then solve the problem
