Inventor Forum
{error} the database in (path of file) could not be opened
2 REPLIES 2
dsmdude
1563 Views, 2 Replies
I have gotten this error several times out of nowhere.  I have been working on a drawing either an .ipt or .idw, have saved it a million times then out of nowhere when I do some function, create a dimension, line, delete something, save the file, I would get this eror:
Delete sheet: problems encountered while executing this command.
   - the databse in \\filepath\filename.idw could not be opened
I just got this trying to delete a sheet, now anything I do it cannot go forward.  If I close the file then I canoot reopen it.  it will give me the same error.
I did nothing for this to happen.  it happens to me just about every other part that I create. I sometimes get saved by the old versions, but sometimes I lose alot because I have not saved the file in some time.
Please HELP HELP HELP!!
Autodesk Inventor LT 2011
2 REPLIES 2
dsmdude
in reply to: dsmdude
The database in \\filepath\filename could not be opened
The database in \\filepath\filename could not be opened severity: SEVERITY_ERROR, facility: ($FFFFFFFF) severity: SEVERITY_ERROR, facility: ($FFFFFFFF) severity: SEVERITY_ERROR, facility: ($FFFFFFFF) severity: SEVERITY_ERROR, facility: ($FFFFFFFF) severity: SEVERITY_ERROR, facility: ($FFFFFFFF) severity: SEVERITY_ERROR, facility: ($FFFFFFFF)
dsmdude
Trying to save it to close the program:
   Problems encountered while saving the document.
       The database in \\\filepath\filename could not be opened
         File \\filepath\filename version 9 could not be located at the given path nor at \\filepath\filename .
           Error opening a storage in database \\filepath\filename
