Inventor Forum
Error Promts
2 REPLIES 2
justinpcaris
346 Views, 2 Replies
Error Promts
I am trying to remove the promt that says "Adding this dimension will over-constrain the sketch. Choose accept to create a Driven Dimension" I have changed the 5th prompt down to never ask and the response to ok but the real response is accept i might be looking at the wrong promt tho, if anyone can help me find the correct one that would be great.
2 REPLIES 2
jtylerbc
in reply to: justinpcaris
I believe you're trying to fix this particular one in the wrong place.
Go into Application Options, Sketch tab.
In the "Overconstrained Dimensions" section, switch the button to "Apply Driven Dimension."
justinpcaris
in reply to: jtylerbc
yes you are right thanks for the help
