Solved by Juliano.rpereira. Go to Solution.
did anybody find a solution for this one of our clients is facing the same problem
More information is needed.
You have not even answered the 4 basic questions posted above.
Is your client still using Inventor 2008?
What operating system and system specs.
(there will likely be more questions as well, but these form a start to defining the problem)
Does File>Save Copy As work?
Is this the first time save or is there an earlier state save?
Oldversions file?
our client is working with
Product Design Suite Ultimate 2013
All fixes installed
all other files save without any problem it only if the user tries to save the file in Autocad .dwg format this error comes up.
regards
Prem
@Geoconsult-ICT wrote:all other files save without any problem it only if the user tries to save the file in Autocad .dwg format this error comes up.
Only this file as dwg or any file as dwg?
Drawing or part file?(the original post says *.idw)
Can it be saved in some other format and attached here so that others can attempt to reproduce the error?(the original post says *.idw)
Try the "Save Copy As" instead of the "Save-As"
tried save a copy as as well as export option, none of them work, it is just that it does not convert a idw file to an AutoCAD dwg tried almost all methods.
Unfortunately, all the poster has given us is that he is on IV2008. Numerous requests for more system information from this user go unanswered.
I wish there is some way one can remove themselves from a post as not to waste anymore time with people that can't answer requests for additional system information.
Blair, we've got two threads here: the old one from 2-1/2 years ago, and the new one from three days ago. Prem (also posting as "Support") has answered most of JD's and your questions, now.
But I think all you have to do to remove yourself from notifications for this thread is unsubscribe (can't tell you how, since I haven't had to do it yet).
Got the solution to this through the Autodesk Support Group, Just needed to reinstall DWG Review 2013 and update 2 for Inventor 2013, this was the culprit as it carries the dwg conversion dll's.
When I got this issue, I went to "Get Started" -> "Projects" and obviously it was pointing to some junk file in "Temp".
I cancelled out & make sure it points to correct ipj file.'
I was able to save.
Hello.
Autodesk Design Suite 2013 x64
I updated everything - SP2 + update for inventor
Also the Design Review and True View were reinstalled.
Still, I get the message "Problems encountered while saving the document" when I save as copy in AutoCAD DWG or export as DXF.
Please, help.
With kind regards,
Alex
I used this solution. Unable to Save As or Import DWG/DXF
Save as DWG, Save as DXF results in:
Import DWG / DXF results in:
