Every atomic change which you can roll back and forth as one unit (via the
undo and redo commands) is effectively a transaction within the system.
Sometimes, some internal changes to the data (such as when you update the
view on a drawing) have to be hooked up (coalesced/attached) with the
previous transaction, so that those changes arent lost if you do an undo and
then a redo. It looks like the system failed while trying to coalesce such a
transaction. I've only seen this message once or twice, and usually it does
not manifest itself into a serious issue, and certainly not if you never use
the undo/redo commands frequently around situations when you encounter these
messages. If you send me a data set with which the issue is reproducible, I
can take a look and find out what's going on. If the data set is too big (>
8 MB), I'll send a link to a FTP site location where you can post the data
set.
Naroo Krishnan
Inventor Development
Autodesk, Inc.
(email) narooDOTkrishnanATautodeskDOTcom
wrote in message news:5666603@discussion.autodesk.com...
I get the following message when I try to update a view on a drawing.
Cannot coalesce given transaction with a previous identified transaction.
Does anyone have an idea what this means? Some times it shows up other
times everything works out perfectly fine. Thanks in advance.
