Inventor Forum
Error Message - Solid no longer exported?
2 REPLIES 2
stevec781
377 Views, 2 Replies
I have an assembly with a part and a mirrored copy of it. When I update the orginal the mirror doesnt update anymore - it used to work fine.
There is an info icon that says the 'solid is no longer exported'.
How did that happen? What have I done wrong this time?
Steve
2 REPLIES 2
in reply to: stevec781
Most likely nothing. That error happens at random. All you have to do is to
run recovery tool (red cross) and select the option "Check solid for export"
in the problematic part.
Igor.
Web: www.meqc.com.au
www.boatworks.meqc.com.au
wrote in message news:6302655@discussion.autodesk.com...
Steve
HI Igor,
Been long time since you answered. though when I encountered this error after running the recovery tool I did not get the option "Check solid for export". Though the error was rectified by other option "Mark for export", I would like to know what exactly does this error mean? Could you please help me with that? I am using Inventor 2010.
Srinivas
Igor.
Steve
Tags (3)
