I've been seeing this error message pop up randomly in one assembly file today. I have no ilogic rules present in this assembly or any of the subs or components, so I can't understand why I'd be getting a compile error. Anyone else seen anything like this ever?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
I have seen this error when I try to add a function or secondary subroutine into an iLogic rule, and I forget to specify the main subroutine.
But I can't begin to guess why this error would appear if you don't even have iLogic rules...
Can you attach the assembly in question? Or at least a simplified version of it?
Cameron Whetten
Inventor 2014
Assembly way too big. I started clicking "delete all rules" at each assembly level where I've seen this error, and I haven't seen it in a while. I'm hoping I "purged" the rule (which didn't exist in the first place). The only other thing I can think of is that I had iMike in the assembly for a while... there may be rules embedded in that thing which were affecting me.
Chris Benner
@mrattray wrote:
iMike?
Inventor assembly of a generic "man" for judging heights and ergonomics and such. You can adjust his height and position arms, legs etc.. even make him sit. Fairly popular for a while, I found it on the cbliss website years ago. We use it once in a while to check the height of valves or controls etc. I've heard there is an iJill as well which is a more advanced assembly with articulated fingers and such. Never looked for that one.
Chris Benner
