When I suppress a part or a sub-assembly in Inventor 2013 and then right click on the suppressed item in the browser window I always get an cadabundus error message (see attachment), after I press OK I get the normal right click menu hovering over the item. Any suggestion to fix this?
I have Inventor 2013 RTM 64 bit Build 138, and running on Vista 64bit.
Solved by mrattray. Go to Solution.
This looks like a VBA error. Do you have some sort of add-in, macro, or ilogic rule that may be resposible for it?
Hi, thanks for the tip, I looked at the ribbons and recognized the "Cadabundus Apps" that I have. I disabled "Inventor File Paths" 1.0.0.0 plug-in and the problem was resolved. 🙂
Øyvind
