Inventor General Discussion
Member
jd789
Message 1 of 10 (6,140 Views)
Error in inventor undo folder, how can I solve this?
6140 Views, 9 Replies
08-08-2012 08:38 PM
Buenas el error que tengo es este ¿cómo lo puedo solucioar?// Hello this is the error How can I solve this?
Valued Mentor
mpatchus
Message 2 of 10 (6,117 Views)
Re: Error in inventor undo folder, how can I solve this?
08-09-2012 05:11 AM in reply to: jd789
Go to your Inventor options and look at the file tab..
Undo should read ...
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
*Pro
jletcher
Message 3 of 10 (6,114 Views)
08-09-2012 05:58 AM in reply to: jd789
I make a folder under my C drive called inventor undo and I map to that. This way if the error comes up again I can go to that folder and delete everything and restart inventor. All it is telling you is there is no more space for the undo files to go..
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
New Member
sangwenint
Message 4 of 10 (4,389 Views)
08-10-2013 04:01 AM in reply to: jd789
the undo file looks like that but it still doesnt work ...plz help
skhuam
Message 5 of 10 (4,279 Views)
08-21-2013 07:31 PM in reply to: sangwenint
Make sure your C drive got enough space, at least few gb free space. It could be one of the reason fot this message to pop out.
JDMather
Message 6 of 10 (3,594 Views)
11-13-2013 08:25 AM in reply to: skhuam
I just got this error on one of my machines (r2013) and Inventor doesn't launch.
Cleaned the referenced Temp and still no luck?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
mpatchus
Message 7 of 10 (3,591 Views)
11-13-2013 08:32 AM in reply to: JDMather
How much free space do you have?
Recycle bin empty?
Mike Patchus
JDMather
Message 8 of 10 (3,583 Views)
11-13-2013 09:00 AM in reply to: mpatchus
Whoa,
I thought I had a monster HDD that would never fill up, but that was it.  I had no idea that it was almost full.
Now I've got to spend some time taking out the garbage that wasn't in the Recycle bin.
New Member
asilrohit
Message 9 of 10 (1,052 Views)
06-03-2014 08:11 AM in reply to: jd789
copy the link that the message box shows and open that link. It is usually hidden so cant be accessed directly. Manually delete all the files in the folder and you are good to go!
Employee
nate_k
Message 10 of 10 (839 Views)
06-17-2014 03:21 PM in reply to: jd789
The fix for the missing error message will be released in a future service pack.
Nate Kozlowski
Software Engineer - Inventor
