We need to create copies of original Family parts of Content Center to Custom Library. The objective is create libraries with defined materials.
Each component (for Example: Hexagonal Nut DIN 934) can have diverse materials (Example 5.8, 8.8, AISI 304).
Used Procedure:
Step1: Was used the “Save Copy as” function from Original (DIN) component, keeping the option “Link you the parent” selected and changed de field “Family Name” “Family Description” e “Family Folder Name”.
For other copy was used the same procedure, but now from the previous copied family.
Problem:
When any parameter (Field) is changed is any copy, all copies they assume the same values.
To Reproduce:
To create or to use a custom library
Use “Save Copy as” from a original family from content center and change parameters fields.
Use “Save Copy as” from a last copy and change parameters fields
Change the property “Family Name” of one of copies.
See in the content center. Both the families have the same name!
Content center Server: ADMS 2009, SQL server 2005 Express, Windows Server 2003 R2
Workstation: Inventor 2009 (Suite e pro), Windows XP Pro. Dell Precision T3400
Edited by: VDahmer on Mar 3, 2009 6:10 PM
