Hello!
This seems to be a common issue, when trying to download autodesk software (not only Inventor, in my case - Inventor Professional):
When the installer has downloaded, it runs and immediately shows error ''Error Downloading. Please Install Now again from the Autodesk website.''
Already tried to disable firewall, delete the related folders from previous Inventor installation.
Any ideas would be appreciated
Solved by DannyHubbard. Go to Solution.
Check out the following, try using the 3rd option for the Virtual Agent.
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
Once at the virtual agent pick on Download Links, then the product and version you wish to download.
If downloading the 64-bit version of Inventor make sure to download both Part1 and Part2.
Danny
Danny, is there a link like this for the newest version of Inventor?
Aaron,
Yes using the Virtual Agent and the Download links, mentioned above, you can download Inventor 2015
Danny
