Hi there,
Did you ever get the issue resolved? I got this message after I did a "Save As", closed the file and then on re-opening the file I got 2 pop-up windows. One said "Attempt to create one first" and the next window "A required recourse was".
Wynand
In the future I would recommend creating a new posting and not replying to one that is 8 years old. As you can see the original user's account has been archived.
However what happens if you exit Inventor 2015 and then open the file? Do you have Inventor 2015 SP2 installed?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Just got the same message, btw who says you can't reply to an old post? haha
Hi! The error message sounds system related. Try a few things. Close Inventor and go to %temp% and clean up files there. Make sure the appropriate .Net is installed (2020 and 2019 require .Net 4.7; 2018 requires .Net 4.6; 2017 requires .Net 4.5).
The issue seems to be known. I found a support article dated in 2018. The issue was reported as 14484. I need to check the status.
Many thanks!
Hi! Based on the status of TFS-14484, it has been fixed as of 2019.4 and 2020 RTM. What release are you on? Have you applied 2019.4?
Many thanks!
Hi @johnsonshiue, is there a 2018 fix for this one in any patch? Thank you.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Hi Gabriel,
Unfortunately, based on the record I am seeing, the fix is only available to 2019 and 2020 at the moment. Please feel free to contact Autodesk Product Support to escalate the issue and request a fix in 2018.
Many thanks!
