Inventor General Discussion
Member
0 Kudos
Post 1 of 5
Error 1920
623 Views, 4 Replies
12-14-2012 03:43 PM
"Error 1920". "The Service failed to start. Verify that you have sufficient privileges to start system services." This always comes up everytime I try downloading Inventor 2013. I am also a student,so I get it for free. I have tried running it as an administrator, but it still doesn't work. I have already downloaded all the needed drivers. I am attaching a screen shot. Please help me with this. Thank you.
*Pro
285 Kudos
Post 2 of 5
Re: Error 1920
12-16-2012 05:32 PM in reply to: rsoni1997
Let's be clear on terminology to start with-- it looks from your screenshot that you are installing Inventor 2013, not downloading it, correct?  Downloading is how the installer gets to your computer from Autodesk's website, installing is getting the software configured and ready to run on your computer.
When you run the installer have you set your UAC to minimum and stopped your antivirus utility?  Do you have administrator privileges?
Member
0 Kudos
Post 3 of 5
Re: Error 1920
12-17-2012 02:07 PM in reply to: sbixler
It doesn't work
Member
0 Kudos
Post 4 of 5
Re: Error 1920
12-17-2012 02:14 PM in reply to: rsoni1997
Is there a way an expert could remotely look at the problem and fix it?
The problem happens when I install the Inventor 2013. The problem only shows up when it's installing inventor.
1,706 Kudos
Post 5 of 5
Re: Error 1920
12-17-2012 03:16 PM in reply to: rsoni1997
Hi rsoni1997,
You might ask this question over here:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Autodesk staff  actively monitor the Installation & Licensing forum, working with the existing community to answer your installation and licensing questions.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
