Inventor Forum
Error 1402 - Could not open key during installation
2 REPLIES 2
mthomas
3530 Views, 2 Replies
Attempting to install Design Suite Ultimate 2013 on a Windows XP Pro 32-bit system and right after entering the s/n and product key and clicking next causes an error 1402. (i'll attach a screen shot)
The key it lists as a problem does not exist. I used regedit to add my user within the permissions of the Autodesk key within Local_Machine and change the owner to Administrators on the Autodesk key and all of its children. What else can I do?
I also tried to install both from the network deployment and locally installing
Mike Thomas
2 REPLIES 2
SBix26
in reply to: mthomas
I hope I'm not violating any agreements by posting help I received from Autodesk through our subscription, but here are some quotes from a message I received concerning the dreaded 1402 error (note that some of this applies to Windows 7, not to XP):
... I will be working with you to resolve this case where you are getting the 1402 error with the incomplete registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\\RegistryVersion17.0.
However, when applying the patch, the Windows Installer service is unable to correctly resolve this path as it should actually be the following:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor\RegistryVersion17.0
Since we worked on the original case related to this same issue last summer, I discovered that the Windows Installer service sometimes will incorrectly resolve the path, making it incomplete as in the first path above, when the user permissions launching the install are reverting to the User level instead of the Administrator level of permissions.
To test this, please verify the accounts listed with permissions to the key, by right clicking on the Autodesk key and select Permissions:
Make sure that the Users\<account_name> as well as the Administrators\<account_name> have full permissions to this key. I was able to work with another user who experienced this error and setting the full permissions for the User account on this key as well as the Administrator, resolved the issue and the patch was able to apply successfully.
Also, verify that the User Account Control Settings are set to the minimum level during the install sequences. The following link provides additional information on the behavior of the different accounts when the UAC is in effect:
http://technet.microsoft.com/en-us/library/cc709691(v=ws.10).aspx
Unlike earlier versions of Windows, when an administrator logs on to a computer running Windows 7 or Windows Vista, the user’s full administrator access token is split into two access tokens: a full administrator access token and a standard user access token. During the logon process, authorization and access control components that identify an administrator are removed, resulting in a standard user access token. The standard user access token is then used to start the desktop, the Explorer.exe process. Because all applications inherit their access control data from the initial launch of the desktop, they all run as a standard user.
After an administrator logs on, the full administrator access token is not invoked until the user attempts to perform an administrative task. When a standard user logs on, only a standard user access token is created. This standard user access token is then used to start the desktop.
I'm including a link to a Forums post from David Lau that also contains additional background on this issue:
http://forums.autodesk.com/t5/Autodesk-Inventor/Instalation-error-1402/td-p/2951156
http://forums.autodesk.com/t5/Installation-Licensing/Error-1402-during-uninstallation-Could-not-open...
mthomas
in reply to: SBix26
Thanks for the post... I got it installed with one or all of the following 4-things fixing it...
1) Ran Microsoft Fixit with the option to fix installing programs
2) Did not include SP1.1 with the installer, going to attempt to install it now
3) Installed from local admin account opposed to my admin account on the system
4) Added Everyone with full permissions to KEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
Mike
Mike Thomas
