Inventor Forum
Equation Curve problems in polar coordinates
4 REPLIES 4
spectoad
599 Views, 4 Replies
There seems to be a problem with the equation curve editor in polar coordinates. I am trying to draw a spiral pattern defined by the parametric equations {r(t) = t} and {theta(t) = (t-500)*PI} from t = 500 to t = 504. If I define these equations from t = 500 to t = 504 the curve generated is not actually the one defined by those equations, however if I define two separate curves from t = 500 to t = 502 and t = 502 to t = 504 the combination of these two curves is the result I'm looking for. Obviously these two methods should both produce the same curves, but in practice they definitely don't so I believe there is a bug somewhere in the equation curve programming. A work around would be that I could individually define these curves and then combine them to get the full curve, however since I would actually like to go from t = 500 to t = 1000 this would be far too time consuming to actually do. Thanks for your help!
4 REPLIES 4
johnsonshiue
in reply to: spectoad
Hi! What Inventor release are you using? I just tried it on R2015 but I did not see the problem using the following equations.
r(t) = t
500 <= t <= 504
Thanks!
Software Test Engineer
WHolzwarth
Hmm. IMO, the result seems to depend on the document settings. Try this:
- Start a new IPT with Extras-> Document settings -> units -> Angle -> radiants
- Define now the equation like in the 1st picture. I think, you'll get the expected result
Go back to Document settings and change Angle to deg. Define the next EDC like below. I think, you don't want that.
Now change the 2nd equation like in the last picture. I think, that's your intented curve.
Walter
Walter Holzwarth
spectoad
in reply to: WHolzwarth
Sorry I should have been more clear, the issue only seems to be when I'm using micron length scales. So the spiral pattern works correctly if r(t) = 1 m* t or r(t) = 1 mm* t, however when I use r(t) = 1 micron* t it gives me the incorrect result.
WHolzwarth
Smiley WinkBest way for further discussions could be attaching your file.
Walter Holzwarth
